1999 Galant only blows hot air
Hey folks,
I have a '99 Galant and a few months after buying it, the a/c stopped working. When I turn it on, it makes the engine rev up and down and there is no temp control (only blows hot) so I don't run it any more. I run the heat but it only blows hot air no matter what the temp setting and once in a while it makes the engine rev slightly up and down, so I rarely run it for more than 30 consecutive minutes. Any ideas? |
Originally Posted by c0mm0nism
(Post 280876)
Hey folks,
I have a '99 Galant and a few months after buying it, the a/c stopped working. When I turn it on, it makes the engine rev up and down and there is no temp control (only blows hot) so I don't run it any more. I run the heat but it only blows hot air no matter what the temp setting and once in a while it makes the engine rev slightly up and down, so I rarely run it for more than 30 consecutive minutes. Any ideas? Sounds like you have a leak |
what is the pressure readings of the a/c freon ???
