2000 Galant
Old 02-23-2011 | 11:00 AM
tazzo42's Avatar
Default 2000 Galant
Having a problem. My engine light came on , I took it to the shop had it checked out replaced the EGR valve, mass air flow sensor, cam shaft position sensor,o2 sensor the car still feels like it going to shut off when stopped at a light. My question is should changing the plugs and wires help with the idle? I have 102,320 on the dash . Any suggestions ?
Old 02-25-2011 | 07:49 AM
Fe2O3's Avatar
Need you to post the code(s) that's setting off your check engine light. Auto parts shops will usually pull it for free. Autozone, Advance, etc. Don't bother having them clear the code, that won't fix anything.
Just guessing without seeing your code, but since you've replaced the egr and other components, I'd suspect (or check next) one of the solenoids that actually trigger the EGR to open the valve is defective. If the solenoid is telling the EGR to open when it shouldn't, you'll get too much air in your fuel mix and the car will bog down or stall.
Again, get the code and post up.
Old 02-27-2011 | 08:43 PM
tazzo42's Avatar
The code that's on now is P0125 . If i'm correct that's the engine coolant sensor where is the world is that located ?
Old 03-03-2011 | 07:57 PM
Fe2O3's Avatar
Info on that code:
http://www.obd-codes.com/p0125
On 4cyl engines, it's located on the opposite end of the head from the belts, left of the thermostat.
On v6, it's on the housing with the thermostat, IIRC.
From that webpage, the code doesn't mean you necessarily have to replace it.
Old 03-04-2011 | 04:46 AM
tazzo42's Avatar
Thanks for the information . I'm hoping that's all it is, the engine isn't running hot at all . Will keep you posted .
Thanks again!
sweezy18
05-24-2016 06:43 AM
JFENDERSON91
10-10-2012 11:24 AM
maimunatu77
09-09-2004 05:40 AM
maimunatu77
09-09-2004 05:37 AM
Salazar
10-04-2003 09:36 PM
Quick Reply: 2000 Galant
