P0705
Old 05-27-2009, 10:56 PM
Phredawgy's Avatar
Default P0705
Mother in law's 2003 Galant has the SES light on...when Pulling the code I get
Transmission Range Sensor Circuit Malfunction (PRNDL Input)
Anyone know the exact cause or fix for this?
Any help is greatly appreciated
Old 05-31-2009, 08:57 PM
jgbrules's Avatar
that is a code for the trans range switch or it can be called an inhibitor switch. dealer part only. unless you get a used one. i havent seen many of those go bad, but it is an electronic part, so...... it can fail. make sure the connector is not corroded and isnt loose, i have seen that before. its located on top of the trans, big connector and the shift cable hooks to it. keep us posted. greg........
johnnycz
08-23-2023 11:06 AM
jrmdir
07-14-2017 01:17 AM
Quick Reply: P0705
