-   Mitsubishi Galant (https://mitsubishiforum.com/forum/mitsubishi-galant-13/)
-   -   2001 Galant Not Starting (https://mitsubishiforum.com/forum/mitsubishi-galant-13/2001-galant-not-starting-40948/)
03222009 Nov 3, 2011 05:34 PM
I have a 2001 Galant and it is not starting. It just clicks when the key is turned. We bought a new battery, a new starter and we had the alternator checked. We've also made sure all spark plugs are fine and checked the fuel pump as well. All of that is fine and it still does not want to turn on. It was fine last week and one morning I went to leave and it would not turn on not even with a jump. I am at a lost as to what else it can be. Any ideas?
Galanthighspeeder Nov 11, 2011 08:39 PM
Did you check for Codes?
pen1137 Nov 21, 2011 08:53 PM
We have the same issue...it's at the shop now and they can't retrieve the codes and said it will have to go the the dealer (40 miles away, argh).
03222009 Nov 22, 2011 02:19 PM
Yes, and the code was for the crankshaft position sensor. It was changed and the car still did not start. The code went away once it was changed but the next day it was back on and it came up the same code.
Galanthighspeeder Nov 23, 2011 11:15 AM
Did you change the Cam Sensor?
If the Cam Sensor is bad it
wont let the engine start.
IDK Mar 18, 2022 05:16 PM
My car read same code {crankshaft sensor} so I change it and now I have no codes reading and I'm still unable to start it I'm confused myself..
