2005 Galant water on passenger side floor
Everytime it rains the passenger side floor get wet. Don't think it is heater core related (no odor). I need help, is there a drain plugged on that side or something else. If so how do I get at it.
Was windshield ever replaced? :confused: That's a common cause.
Galant
Yes, It has been a couple times. Is there some ammo I can you with the installer, other than it didn't happen when we bought it. I purchased this new. We had some work done it at Mitsubishi, but I don't think that work had anything to do with a leakage problem. Is there a weep hole on this vehicle for drainage on that side? I appreciate your help.
Sorry, not familiar w/Gallant.
most glass shops diagnos water leaks. call where you had the windshield put in and ask them how much it would cost to diagnos a water leak. let them diagnos it, when they tell you its the seal on the windshield, whip out your paperwork and show them that they put the windshield in, and should fix it for free. crawl under the car and on the passengers side floor pans youll notice 2 or three round rubber plugs. you can take them out and the water should drain.
05 Galant
Thanks All, I will let you know how this all works out. All your help is appreciated.
