4G63t Replace for 4G64
i wanted to know from the galant gods if i buy a 4G63t 2.0L would it good in my engine bay or is it easy to just build around the 4G64
RE: 4G63t Replace for 4G64
What car....?
1996 Galant or show i find a v6 3.0
It can be done...for 7g Galants of the years 96-98 its a fairly easy swap. You will have to add wires w/ pins and move some pins around the stock harness (Same excact4 plugs as the2g turbo Eclipse/Talons)to accomondate a 2g turbo ECU and the coil pack, CAS, knock sensor. A 4G63t 7bolt will drop right in w/o no issues like it belongs there, if you decide to go with a 6bolt 4G63 you will have to modify the drivers side motor mount bracket a bit to accomodate the 7g motor mount. If you have a 94-95 Galant..they have a 3 plug ECU with a hybrid OBD1 / OBD II Ecu and the easiest but hard to find route is finding the ever rare 1994 Galant "GS" with came with a DOHC 4G64 stock and do with that set up. I suggest going to this site which I have been a member for a long time and there are a couple of 7g owners that have 4g63's in their 7g Galants.http://www,thegalantcenter.net
http://img81.imageshack.us/img81/898...m002023wq1.jpg |
thanks alot
now this is what i would like to know right here in this link http://www.japangeneralmotor.com/engineInfo.php?link=77 you see it say AWD Trasmission do i really have to use that trasmission or can i use my fwd tranny or even the 2g
and i found a engine but can i use the Wiring Harness that comes with that engine in my car and if so what would i have 2 do than
