4g93 loom
Hello,
I have the possibility to buy a 4g93DOHC engine for my Galant. The current engine is a 4g93SOHC. Do I need to replace the wiring loom aswell or does it use the same type? |
RE: 4g93 loom
it uses the same one
RE: 4g93 loom
If I were you I'd go with the DOHC 4G63t, it's a 2.0l and have a stronger block to put boost on.
And also, they have more HP. i have a 4G64 that produces 147 hp. I'm selling that, if you want it. But I would go with the 4G63t. They go for around 1500 on ebay, that's for a JDM one though. |
RE: 4g93 loom
The JDM 4G63t does not bolt in to the USDM 1999-current Galants. It will however fit the 1994-1998 7th Generation Galants.
You need to use the 4G63t from the Lancer Evolution 5+. Preferably just buy a engine out of a EVO8/9 because they'll be the most readily availible in the States. |
RE: 4g93 loom
The 4G64 block from a 8G Galant is also a very good block to use. IMO I would go with a 4G64 block and use a 4G63t DOHC head....
RE: 4g93 loom
That or just put a turbo on a 4g64 with low boost (and as you know Prophet) many have done that with great results, and MUCH lower cost investment than a 4g63t headswap or engine swap.
