8g galant prothane mounts & cluster question
I recently changed my mounts but theyre soft & still throwing a lot of bad vibes. I saw online that extremepsi dot com carries prothane mounts for 95-99 eclipse & that these should fit but they only have it for manual trans & I have a/t. Are they thevsame mounts?
Second question is about my cluster lights. When I flick on the parking or headlights the cluster only fails to light up sometimes but if I switch the lights off & back on again they work. Any ideas as to whether its the cluster or the switch? Or even the relay? I hate testing for intermitant problens |
No one has put polyurethane mounts in their 8g?? I dont want to get the mounts & get screwed. Id rather know up front if I should get them or if I should buy some 3m window weld and lay the car up for 2 days
8g polyurethane bushes mounts
Although I can't verify, I have been told that Energy Suspension Evo & Eclipse kits contain most of the bushes to suit 8g Legnum & Galant. Best to stick with OEM rubber for gearbox mount.
