94 Galant V6
my gas gauge dont work properly sometimes its high somtetimes low even if i keep on driving it gets down then go up again what do you think should be the problem hope anyone could help me...
RE: 94 Galant V6
Sounds like the sending unit isn't working properly. Try using techron fuel sytem cleaner (it helps remove sulfur off the fuel level card). If that dosent work your gonna need a sending unit/fuel pump assembly.
RE: 94 Galant V6
ok ill let them checc the sending unit and fuel pump assembly, how will i use the techron fuel system cleaner tho? thankz a lot man
RE: 94 Galant V6
You just add it to the gas and hope it works lol.
