94 Galant wiring
94 Galant wiring
My 94 Galant has no power to the sunroof or to the key buzzer and lights left on buzzer. The overhead light does not work when opening the front doors however the light does come on when the rear doors are opened. The cd deck in the trunk works but I get no power to the control Fuses appear fine. Radio and dash lights work as well as the heat and A/C. Any suggestions? Thanks
RE: 94 Galant wiring
Try looking at a wiring diagram. (It's not so hard, take a look at the symbols, it's easy. This 16 yo can do it!) Determine if one of your connectors is bad, or if a short to ground has occured. Less likely is that the terminals in your connector(s) have become "hogged out", where they are bigger than they are supposed to be. However hogged out terminals usually show intermittent symptoms. I suggest if you do not have a DVOM that you invest on one. Checking for continuity is a good start, but it is not the be all and end all. If it's not one of those problems, I'm sorry I can't help.
Influence
01-03-2010 02:45 PM
