95 Galant ES SUSPENSION PROBLES AGAIN
Hey guys,
Quick question ive searched the forums but really found nothing trying to see if anyone had this problem. I have a 95 galant es just changed my frunt stuts with KYB and put Eibach springs on and I changed sway bar bushings out all was well until 2 weeks ago got a new clunk noise on the driver front again sounds like a bad strut but i went back checked everything and all was solid Do you think its a upper contol arm or lower or both ???? I hate to waste money on both of them but i know a joint has got to be bad on one of them its a rattle like sound only on bumps.
Any help would be great.....
Thanks guys......
Thanks guys......
RE: 95 Galant ES SUSPENSION PROBLES AGAIN
Check to see if there are any recalls on it. I know mine had a recall on some parts of the front suspension. It was "fixed" but then my whole weel fell off because the control arm broke and caused $2,000 in damage. I tried to see if Mitsubishi would help me out since the recalled part only had 40,000 miles on it and broke again. So... now i've learned that mitsubishi suspension parts are made with the poorest quality i've seen. So check and see if there is any recalls. MAYBE you will get lucky and they can do something about it.
