brake pads
What kind of front brake pads work the best besides Mitsubishi pads.I want some that will not produce much dust or noise thanks</P> |
brake pads
If you are running stock rotors factory is probably best. assuming the galant has the same or better brake composition as the lancer that is, ceramic pads. Aftermarket pads are mostly semi-metalic and will ruin the factory rotors. that has been my experience so far. I paid $40 extra for factory pads, rather than $100+ for new rotors. btw welcome aboard<IMG src=smileys/smiley16.gif border="0">my advice is not always best but these guys will let you know if I'm wrong. <edited><editID>madmat</editID><editDate>38109.3376041667</editDate></edited>
brake pads
Cheap pads will squeal ...if you use after market use a high quaility pad I believe Brembo are a good replacement pad for your Mitsu</P> http://www.brembo.com/ENG</P> |
brake pads
What about Bendix i think is the name of them and what about wagner the car is stock thanks</P> |
brake pads
at the dealership the only successful aftermarket pads and rotors were Brembo anything else caused the customers nothing but problems I don't know if they were bendex or wagners but they were what pepboys ,straussand corner shops used most of them were found to be trouble.</P> these are all stock cars galants, eclipse, Montero etc...</P><edited><editID>Mitsu-Tech</editID><editDate>38125.9269444444</editDate></edited> |
