Can I put 17" rims on 01 Galant w/out any mods?
Sup Guys
I'm looking to purchase a 2000-01 Galant and want to thow some Chrome 17's or possibly 18's on, my question is would I need to modify the suspension in order to do this? or can I just throw em on? Im also looking into dropping it. Can I get some feedback from guys who actually have this type of setup and any problems you might have had with it? Thanks |
RE: Can I put 17" rims on 01 Galant w/out any mods?
ORIGINAL: toicy4ya Sup Guys I'm looking to purchase a 2000-01 Galant and want to thow some Chrome 17's or possibly 18's on, my question is would I need to modify the suspension in order to do this? or can I just throw em on? Im also looking into dropping it. Can I get some feedback from guys who actually have this type of setup and any problems you might have had with it? Thanks |
What do you mean by "modify your fender"? what's a spacer? How much does it cost? Is it something that I can install?
Thanks |
you need to get a wide body fender ( cosmetic ) for your gallant, then a spacer is to space out your wheel.....in order to freely steer a wide wheels.
check w/ your local performance shops, or shop on line. ( got one down below, check it...)
eibach springs / wheel spacer |
You can fit 19's without modifing your fender if your run a proper off set and width......
17's will fit with no problem I am running 18's with no problem and this next show season I will be running 19's. |
aiight u can use 18s if u want but the tires has to be 215. or if u go 17s thrown in 225 tires. if the rim offset isnt big, no modification is needed. i have 215/45/17 on and rides fine.
which alloys would you recommend then?
the 19's im on about now. |
ORIGINAL: maverick091284 aiight u can use 18s if u want but the tires has to be 215. or if u go 17s thrown in 225 tires. if the rim offset isnt big, no modification is needed. i have 215/45/17 on and rides fine. |
