Differential service
'00 Galant ES 2.4L auto, 94k miles
I flipped through the owner's manual and couldnt' find any reference to the differential. Does this car require a regular differential inspection / service? If so, how often? Thanks! |
RE: Differential service
the car doesnt have a seperate differential.. It has a transaxle, and that combines the transmission and differential into one piece.
so basically, when you do a transmission service, you also change the differential fluid. and use ONLY mitsubishi trans fluid if you service it. generic substitutes are NOT appropriate. Mitsu recommends a trans service every 30000 miles. |
