engine stalls.....and idles low
ok when at a stop... engine running my car idles low then sonetimes stalls. its a 96 galant s. any suggestions on where to even begin looking to see what the problem could be?
RE: engine stalls.....and idles low
u' need a tune up....replace spark plugs, adjust your timing. if this didn't work, check your fuel systems.( i.e. fuel hoses,pumps, regulator,injectrs etc...)
try using NGK plugs is what the manufacture recommend.
try getting your computer chip reset. has something to do with your intake. if you do have a cold air intake that is.
I'd do a tune up first and go from there.
It may help if you clean your throttle body as well. |
