Front Wheel noise
Hello,
does anybady know what can cause the front wheel bearing to make a noise while driving on bumpy roads? It seems like something is loose and gives clacking noise while driving only on bumpy roads. I just recently changed whole hub assemly in the front passanger side. Do you think that I left anyching loose that causes this noise? While changing hub assembly I used a lot grease. Do you think that it can be reason that one of the part got loose and give this noise? Please, help me out. I appreciate any of your effort. |
Mitsi had a recall on a lot of the galants here in the UK, primarily lower arm failiure...
Would get those looked at. Latest reports even the aftermarket jobbies are bad, go for replacement Mitsi ones expensive but worth it. I've got a similar problem on mine, have replaced the lower arm, shock top, swapping out the shockes this weekend, if it's not that then the onl other thing is the engine mounts... |
Maybe the sway bar need to be replaced.
Yep. 'more likely the sway bar links. My '03 had the same noises. Then they suddenly quit - when the links actually broke in half...
