Headlight Adjustment?
Is there any way to adjust the headlights up some? My drivers side light points down too far, and i can't find any adjustments.</P> 03 Galant</P> thanks</P> |
RE: Headlight Adjustment?
Under the hood up near the headlights I believe there should a "screw" that goes up and down. You should just be able to take a screw driver and turn it up/down. Point them at a wall or garage door where you can see the reflection and adjust until you get the desired altitude. Your mechanic should also be to do this in five seconds and shouldn't charge anything.
