Intake installation problem 06 Galant ES
Old Dec 26, 2010 | 07:56 AM
OverCorrupt's Avatar
Default Intake installation problem 06 Galant ES
Hey there, i recently purchased the weapon-r short ram intake. I had no problems figuring out how to remove the stock airbox n other stuff. But im having clearance problems with the new kit.
First it took me a while to wiggle in the tube between the battery and to fit onto the intake manifold. After that everything is fine till the intake filter.
It will not fit with the ECU? next to the drivers side headlight. Having so many clearance problems with a kit specifically designed for my car, 2006 Mitsu Galant ES 4cyl.
Im wondering if anyone else has ran into such problems as this. It got dark before i could try taking off the protective cover for the ECU? and try to make it fit. so i did not continue. I just wanted to get this up ASAP to get others inputs. and to see if anyone had this problem and what they did.
Thank you in advance!
Old Dec 29, 2010 | 09:14 AM
anjy834u's Avatar
well not exactly similar but i did have some issues like the wiring harness in the vehicle was prolonged and came in contact with heat shield, which in turn led to ground out. This resulted in damage to the engine which gradually died down.
O_P
Aug 21, 2022 03:25 PM
gmdive1
Apr 18, 2013 05:26 PM
johnp2
Sep 4, 2010 01:38 PM
zmarcoz
Oct 18, 2008 10:21 PM
proteusx301
Aug 20, 2005 11:48 PM
