intake manifold
I am wanting to buy a intake manifold made for a 95-99 eclipse N/T 2.0l. could this fit on my 2003 galant 2.4l.
RE: intake manifold
No... RIPP mods is currently developing an intake manifold for the 24L (4G64)... The engine parts from an Eclipse 2000-2005 2.4L is the same engine from the 8G 1999-2003 Galant 2.4L (4G64) will work... not from a 2G Eclipse.
RE: intake manifold
actually i just found that every part except for the pistons can be swapped a 4g64 2.4l and a 4g63 2.0l. Also the spyder came out with a 2.4l in 1996.
RE: intake manifold
Engine is still turned 180.....
Also the 4G63 and 4G64 is two totally different engines.. Who told you this I would like to do some more research? |
RE: intake manifold
i, think 4g63 stuff aint goin to fit your 4g64 ....its two diffrent engines.( check the 63 set up and compare it to 64 set up....)
RE: intake manifold
thats what I did and the set up is the same. so my head should work with a 4g63 custom itake manild because one is they both face the same. also prophet agrees that a 4g63t manifold fit a 4g64 spyder because they are turned 180 degress. but i will test it out let you guys know hopefully next week.
RE: intake manifold
o.k.' let us knoe .....
RE: intake manifold
hi i am new here you say it is the same motor in the 2002 galant as in the eclipse . so could you buy a upgraded computer for the galant that are originally for the eclipse? and would that hold true for the stand alone fuel managemant system? one of my good firends had a turbo talon and he has this really nice fuel managemant program that he could get for a no turbo eclipse of the same year as my galant. so i was just wonder if that would work on my car.
RE: intake manifold
Are we talking about a stand alone for a 3G Eclipse (2000-2005) and upgraded ECU for the same generation to be used on a 8G Galant?
RE: intake manifold
i don't know all the gen stuff but he could get me a stand alone for a 2.4l 2002 eclipse. i was just wondering if that would work in my 2002 galan es with the 2.4l? and where would be a good place to look up parts?
