Looking for Expansion Valve Joint!
1 Attachment(s)
2004 Galant ES. I'm desperately looking for the Aluminum block that goes between the expansion valve and the high and low pressure lines. It's called the Expansion Valve Joint.Attachment 2788
This is NOT the expansion valve. This block does not have a part # through the dealership. I spent 4 hours there yesterday. This is the block that goes between the expansion vlave and where the lines hook up....
Do you have the part at hand? or can you at least draw it? I'm searching for it but cant exactly pin point it, I'm looking through different service manuals to try and find it.
It's not shown in any service manual. I was told by dealership that the only way to acquire the part is to buy the complete A/C Heater unit that includes the Heater Core, the Blower Motor the AC Core etc. I'll post some more pictures later. The only way I found the name the of the part was on a website that diagramed out how to remove the dashboard. They listed it as the Expansion Valve Joint. It can be removed via the engine compartment through the fire wall. The expansion valve can only be removed by pulling the dashboard.
Try a junkyard.
