P0300 Multiple Random Misfires
My '99 ES 2.4 is misfiring and the tach is bouncing all over the place. The engine runs fine and idles but the rpms don't match the sound of the engine. When driven the car misfires under a load but cruises fine. The code that pops up is P0300, Multiple Random Misfires. I've replaced the coils, wires, and plugs. It still misfires and the tach is all over the place. I've checked the injectors, the timing, all the connections, and wires, all are fine. Help. I'm lost. Thanks in advance
Try a compression test and make sure thats 100%, what kind of plugs and wires are you using?
Originally Posted by dsm1990gsx
(Post 255242)
How bad is the oil b/c that will cause issues as well.
The oil was just changed. I tested the EGR today and valve is fine but the electronic part doesn't seem to have the correct ohm reading. I unplugged it and tested it with multimeter and it read 4 ohms.
No, oil getting into the plug wells will cause missfire problems.
(Post 255250)
Could a hole in my exhaust after the first O2 and before the cat cause a misfire? Everything else on the car is checking out fine. The only thing off is the O2's are fluctuating quite a bit. The hole is in the flex pipe.
I am having the same problem. Is there any fix for this?????????
