P0400 code
Manual says this is an EGR valve flow malfunction. How do I confirm? Is this a vacuum test or do I blow air into it and determine if clogged? Thanks
RE: P0400 code
just disable the EGR. don't need it anyway, plus, u'd get better engine performance.
RE: P0400 code
Poor advice. Dont listen to this person.
You should be able to visually see if it is blocked or not. |
RE: P0400 code
It's been a while so i'll and i'm going by memory but if you pinch the vacuum hose near the throttle body (yellow dotted tracer)- it should INSTANTLY stall your vehicle or make it run rough.
JJ |
