PCV Valve - a couple questions
'00 Galant ES 2.4L auto 94k miles
I was looking online for a PCV valve, and found that the price ranges quite a bit from $5 (Hastings)to $13 (Standard). I'm just curious: Do they differ much in quality? The PCV valve currently in my car is L-shaped. The valves that I saw online are either L-shaped or I-shaped. Should I stick with L-shaped valves? Thanks in advance. |
RE: PCV Valve - a couple questions
Go to your local auto parts store and get one, should be about 5 bucks.
The one you buy should be straight, but have an adapter L tube with it. As for if it matters, no not really. All it does is pull oil out of the vent line. no worries |
| All times are GMT -5. The time now is 05:39 AM. |
