please help me in overheat issue
Dears
i have an overheat issue after changong time belt , i have replaced a lot of parts with no luck now at least i can say the fan dont come in high speed i mean there is no order to my fan to speed up , dont know if the car computer dont send the order or dont know if the car overheat the strange issue the car will not overheat while AC is runing at all and the fans work strongly / as expected with AC what do you think ? |
sounds like a bad fan temp switch
can you please give me more info.
where is this swich ? how i can change it i am waiting you please send me ASAP |
thx a lot
can you please give me more info. where is this swich ? how i can change it and is there anyway to test it before change this part i am waiting you please send me ASAP |
i have been reading some of the posts about overheating and i am having the same problem, i have an 02 galant 2.4 sohc that is overheating. I have repaired the head gasket, thermostat, water pump , and temperature sensor. i have flushed the radiator and have have a good flow however the car keeps over heating on me of course its starts out fine then shoots up to the H. I am wrecking my brain on what it could be, does anyone have any insight on this. Thanks in advance
