Problem after engine mount replacement ['99 Es]
Hey guys,
Yesterday while replacing all of my motor mounts, I ran into a problem with the transaxle motor mount that required me to lower the engine a bit to its side, so I could slip the mount off. Now after all that, when im driving my car jerks right when 2nd gear kicks in and my "Service Engine Soon" light came on. I got the code checked out and it showed: P0715 Input/Turbine Speed sensor A circuit malfunction ....Man, Im totally clueless here, but im really hoping is nothing critical. |
you left the input sensor unplugged, broke the sensor, or damaged the connector. that code is for the input speed sensor on the trans.
| All times are GMT -5. The time now is 10:17 AM. |
