Servicing
my newly purchased galant v6 is due its 9k service
can anyone tell me what it involves and does it HAVE to be done by a dealer? thanks d |
RE: Servicing
no worries
rang a local dealership big service every 54k miles this includes timing belt change new spark plugs oils and filters etc 4hr service just shy of £600 :eek: |
RE: Servicing
i just drove from texas to New York. The 2000 galant has 81,000 miles. We just put on another 1600 this weekend.
Performed a minor tuneup which consisted of changing the following: oil / filter transmission fluid spark plugs checked tire pressure (tires are relatively new) wiper blades The car drove like new again. felt really great. To be done in the near future: shocks/struts timing belt accessory belt Are there any other maintenance items to change? pcV valve? Gas Filter? (connected to the gas tank) |
Timing belt
I just recently drove my 98' Mitsubishi Galant from southern GA to central wisconsin. The tempature recently dropped down to negitive 20 degrees, i originally thought possible frozen fuel lines, but gas is getting to engine. The battery is keeping charge and the engine is turning over but i just want to figure why the engine isn't starting up. All electrical seems to work fine. Would the timing belt give me the same type of trouble?
RE: Timing belt
ORIGINAL: lhs_45 I just recently drove my 98' Mitsubishi Galant from southern GA to central wisconsin. The tempature recently dropped down to negitive 20 degrees, i originally thought possible frozen fuel lines, but gas is getting to engine. The battery is keeping charge and the engine is turning over but i just want to figure why the engine isn't starting up. All electrical seems to work fine. Would the timing belt give me the same type of trouble? Does it sound like its spinning over but getting no fire? |
RE: Timing belt
the engine is turning over but not starting up....
RE: Timing belt
9k service is just oil and filters
its the 54k service that will cost £500 average |
