Transmission Problem - Please Help!!
Old 10-27-2003, 06:23 AM
97teg415's Avatar
Default Transmission Problem - Please Help!!
Hey guys, I just picked up a transmission from a 94 DOHC 4G63 Galant GS and was wondering if it would fit into my 95 SOHC Galant S? Can someone please help me, thanks!
Old 08-13-2009, 07:55 AM
Tenchu2047's Avatar
Default gearbox
hi wonder if anyone can help me i own a 2003 2.5 24v v6 Galant. when i start my car from cold i cant put it in gear. However i can put the car in gear when engine has not been started. i have to start the car in gear when the car has warmed up it slips into gear fine. what could this be
Old 08-13-2009, 01:07 PM
BEAT's Avatar
You must have leak on your tranny or you need to have a Tranny fluid exhange just like an oil change. Or you must have a leak on your tranny if there is a low fluid it tends to be hard to shift the gear during cold weather.
that what happened to my Honda 1993 I have steering rack leak and the steering wheel was very hard to steer. I had to wait until the fluid was liquify so I can turn the steering wheel.
do that first by replacing a new tranny fluid. if not post again
Look under the car if there a leak you have a big issue,check the shift boot for debris,shift cable is bundled if you have one.
Libra0281
06-01-2004 12:24 AM
oj0hn
02-04-2004 07:20 AM
clcrig
01-16-2004 05:29 PM
Riktar
01-14-2004 05:38 PM
crackhead365
10-27-2003 05:31 AM
Quick Reply: Transmission Problem - Please Help!!
