Transmission Problem - Please Help!!
Hey guys, I just picked up a transmission from a 94 DOHC 4G63 Galant GS and was wondering if it would fit into my 95 SOHC Galant S? Can someone please help me, thanks!
gearbox
hi wonder if anyone can help me i own a 2003 2.5 24v v6 Galant. when i start my car from cold i cant put it in gear. However i can put the car in gear when engine has not been started. i have to start the car in gear when the car has warmed up it slips into gear fine. what could this be
You must have leak on your tranny or you need to have a Tranny fluid exhange just like an oil change. Or you must have a leak on your tranny if there is a low fluid it tends to be hard to shift the gear during cold weather.
that what happened to my Honda 1993 I have steering rack leak and the steering wheel was very hard to steer. I had to wait until the fluid was liquify so I can turn the steering wheel. do that first by replacing a new tranny fluid. if not post again Look under the car if there a leak you have a big issue,check the shift boot for debris,shift cable is bundled if you have one. |
