Turn Signal and Hazard Lights not working!!!
RE: Turn Signal and Hazard Lights not working!!!
Things got worse. My father-in-law was checking it out. I don't know what he did but he stuck a probe in the hazard light fuse and all the light on the car turned on. I had to disconnect my battery to shut the damn things off!!!
hello! you have pinched a harness in the radio area and several wires have been cut and are shorted to ground. take out the radio and faceplate. get a bright light and shine it in there. grab each harness in there and inspect VERY carefully. to blow that many different fusesseveral wires have been cut, pinched, ect.. when you put the stereo in did a harness get in between the radio and the bracket that it mounts too?? that is usually what happens. look carefully!! good luck!! keep us posted!
[sm=happybounce.gif]I finally found the problem.I had to take the right fender off. underneath it are all the wires that lead into the cabin. There I found a mess of melted wires all caused by years of water and ice and dirt deteriorating the wire protection.Re-wire the bad wires and my car is as good as new.
The cradle for the stereo is problematic did you earth the stereo thru the body canyo
is the maggie speaking to you. Turn the stereo up right up! She is missing an earth or one of your plugs ot the 2 relays under the stash spot near the dash is either touching the body pos+ or the plugs are not connected properly or s fscrew isnt tight or your heater has become disconnected or the wiring harness has been mooved and needs to be re awakened try wiggling the cpu leads
Help my maggie isnt indicating after i fixed heater core
[QUOTE=Reborn1978@yahoo.com.au;333658]. Help. Theres nothing wrong with her she was working perfect. First the windows stopped now the indicators not working.
ps. Went over huge pot hole s in the road!!!!!!!
the door. The actuator?????
