Turning engine but not starting
Hi guys, My car turned off driving on highway,for unknown reason just turned off, engine turns . I replaced timing belt ,cam and crank sensors ,i checked fuel relay good, fire to spark plugs good , i tried starter fluid but to no avail.any suggestions?::confused:
battery. Compression.
Originally Posted by Akzle
(Post 306854)
An auxiliary starter gets the turbines turning fast enough to make the compressor blades create enough pressure for combustion to occur to keep it going on it`s own. Additional fuel flow gives it enough to create thrust and propulsion.
