Water Pump belt
Galant 95
does a drive belt run the water pump? if so, which one and where is the water pump located. Which is pulley I see a pulley connected to alternator and one for power steering. Also, I see another pulley to which there are belts running from both these pulleys. This pulley has two wheels and look like two pulleys. Is this the pulley connected to the water pump?? If these belts are removed, would the water pump still run? |
