where is my ECU?
I bought one of those performance chips and according to the cheezy diagram it is supposed to be right behind the glove compartment. Well I took that area apart and all I saw was the blower for the A/C fan. I went to a couple of auto part stores to find a manual and no one seems to have one for a 2001 Galant. Can someone help me out!!!!
where is my ECU?
Check behind the center console. You may have to take out the center panels(where the shifter is) and the look. I know mitsubish had the ECU in that spot for a lot of their cars in the early and mid 90's, but maybe they changed it. <FONT color=black>If no luck finding it there, then go to The galant center. Those guys can tell you everything about everything about your car. The link is www.TheGalantCenter.com </FONT></P> Good luck, but what kind of chip did you get?</P> |
where is my ECU?
its in the front center of your car you'll have to dig for it but its there pull the panels off your console from the leftside remove the 10 mm boltsrepeat on theright side remove the metal plate and you got it
