06 Lancer OZ Intake/MAF Problem
Was Bout To Install Air Intake On Lancer....Saw MAF Sensor....I Couldnt Find Anything To Fit On Box End Of It....So I Put Everything Back...(Stock Intake).....Now Car Stalls....Idles Too Low...Check Engine Light Is On....Sluggish...I Already Disconnected battery for 15 mins.then let idle for 10..but nothing happended.....trying to figure out whats wrong?...only 10k miles.....has warranty...but i dont know if i voided it....if i did..i have to pay for $500 MAF Sensor
RE: 06 Lancer OZ Intake/MAF Problem
not sure but its possible you have the MAF in the wrong way, the arrow for the flow facing the wrong way. The other thing is, if you didn't hook up the small hose properly or you have an air leak between the throttle body and the MAF.
its in the right way....i checked it for leaks....and im pretty shure there isnt any....idk what is the problem
