09 Lancer GTS Starter Problems...Anyone else?
I have an 09 Lancer GTS...less then 1k miles, and this morning I tried to start the car and the entire ignition was locked. I have a smart key, I tried taking off the cap and putting the smart key in directly and it was still locked. Tried the 2nd smart key...nothing. I research this just on google and found some others experiencing similar problems. Any help here?
I was finally able to get the key to turn but this was extremly frustrating and I was more then 15 mins late today. Help?!?! |
RE: 09 Lancer GTS Starter Problems...Anyone else?
Hey i have the same car and i never had that problem most of the time for me is the steering wheel was locked but that was it but i never had a problem with the car starting and my car has only 800 miles or so
whenever it happens to me i turn the wheel slightly and the key turns no problem
ORIGINAL: dep82 whenever it happens to me i turn the wheel slightly and the key turns no problem |
That was the steering wheel LOCKED.
the ignition will not lock or the starter. next timesimultanously turn the key and steering wheel it will unlock. |
I've had it not detect the key.. even though it is in my pocket as I'm sitting in the driver seat multiple times.
I've had it lock a few times to... but once I unlocked the steering wheel I have never had problems. You guys have less then 1k miles on it. damn I'm near 3k. |
hi..i have the same car and like last month mine did the same. it was really cold here where i live, was it where you live?? i though it might be that, not sure. when i take my car in for the 6 month check-up, i will be sure to ask.
ORIGINAL: hagansp I have an 09 Lancer GTS...less then 1k miles, and this morning I tried to start the car and the entire ignition was locked. I have a smart key, I tried taking off the cap and putting the smart key in directly and it was still locked. Tried the 2nd smart key...nothing. I research this just on google and found some others experiencing similar problems. Any help here? I was finally able to get the key to turn but this was extremly frustrating and I was more then 15 mins late today. Help?!?! |
lancer 054 you are funny
Mine is simple ignition key but also took me 2 years to figure out my DASH BOARD SYSTEM. especially pain inthe butt service reminder. Thank god I don't drive expensive cars the more I will have problems figuring out the controls on the dash my 2008 Lancer is like giving me a test in how to operate or read the dash good luck to those people with NAV system and FAST Key they must having a ball figuring out there car system. |
Help
I Have an 09 GTS Lancer, 254 miles. THe car wilol not start. Steering wheel is not locked. LIghts are on dash,everything electical works. Car is a manual and I have the clutch down. THe car started fine 30 minutes before. Is there a seciurity system that needs to be reset? Any other thoughts?
