2002 Lancer 5spd Question about 5th gear + high speeds
This is my first manual car so excuse me if my terminology isn't that great!
I just bought the car 3 months ago, it has 130k miles and I'm the 2nd owner. I've mainly been driving it around town and a bit on a highway (but not above 65mph) My dad taught me to drive by listening to the engine to know when to upshift/downshift but I've also been looking at rpms. If I pay attention to the rpms I will shift up at 2.5-3 and downshift when the engine sounds bogged down/rpms are below 1.5-2 When driving, 4th and 5th gear seem EXTREMELY short. I will shift up into 4th at 40mph/3rpm and then have to shift up again to 5th at 50mph... Seems really short to me or am I wrong? Additionally, I take trips on a toll road where the car will need to go 85-90mph for a good 2+ hours. But the way 5th gear sounds, she won't go above 70 without being very loud and rpms being up in the 4's. Which according to what I've read, 4rpms isn't that bad but if I listen to my dad's advice then the engine sounds awful and needs to shift up (but I can't since it's a 5 speed). I guess the question is, is it okay to drive the lancer at 85-90mph even if the engine sounds awful? Is it normal for manual transmissions to be that loud? I feel like even if it is okay to drive the car that fast for that long, the higher rpms are going to kill my mpg... Any advice is appreciated! Let me know if I forgot some important info |
My 2010 sounded really wound out in the highway until I put new tires on. Turns out the stock tires were really loud, Michelin Defenders make a huge difference.
Lancers have an issue with the main bearing in thee transmission and it will start making noise. By the way it won't be making any power until 3000 rpm. I shift between 4000 and 5000 and do a lot of fast highway driving over 500,000 on my 2003 lancer
The only time I do a lot of up shifting is when I'm still in the low gears. By the time my lancer is in 5th gear...I'm already at cruising speed and I find no need to floor the gas pedal by then. There is no one particular way to drive a manual car. For instance, I do not shift based on the engine sound or by watching the rpms on the dash. I shift, either up or down, based on how much power I need. The only time I watch the rpm is when I want to take off fast at low gear. I stay on a low ratio gear until the rpm meter almost touches the red line when I shift to the next higher gear.
