2003 Lancer OZ Rally Intake Help...
Hello everyone.. I just got a 03 Lancer and I want to put an intake in it. I was looking at the air box and noticed like a wires going into this plug thing.. does anyone know about that?? And my another question is that will a cold air intake fit or do I need a short one? Thanks!
RE: 2003 Lancer OZ Rally Intake Help...
its easy the wire that you see is the wire that pluggs into the Mas air. you will need to unhook the masair from the air box and use it with your new intake. and if a cold air is made for your car then it should fit.. here is a pic of a short intake after intall(it is on a eclipse but it is the same thing)
thanks you.. that helps.. does anybody know of a cold intake made for a 2003 A/T Lancer OZ Rally.. where can I get it from? Thanks!!
try injen:injen intakes
cant put a cold air on an auto, short ram will do the trick tho
Originally Posted by jrathod
(Post 22732)
| All times are GMT -5. The time now is 04:12 AM. |
