-   Mitsubishi Lancer and Lancer Sportback (https://mitsubishiforum.com/forum/mitsubishi-lancer-lancer-sportback-11/)
-   -   Brake drum removal help please.... (https://mitsubishiforum.com/forum/mitsubishi-lancer-lancer-sportback-11/brake-drum-removal-help-please-52988/)
Hc123 Mar 10, 2019 01:25 AM
Hi all, can anyone please advise how I can remove this Lancer 2013 rear drum. I have been trying for a couple of hours. Any help greatly appreciated.
jsfguy Mar 11, 2019 12:28 PM
Can you adjust your parking brake from the handle? What year? Try to adjust the brake loose so the shoes inside the drum will relax & it will fall off with ease.
jburney Mar 12, 2019 08:12 PM
Dont know your vehicle, but...
If there are threaded holes on the drum, find some metric bolts that fit and push the drum off.
Many cars also have a rubber grommet on the back over a window that gives access to an advancing mechanism. With some knowlege and luck you can loosen the brake shoes.
