Defective idle control servo... Improvise!
  #21
Old 05-22-2017, 11:21 AM
Tupoy's Avatar
Default Post servo kit bypass issue 1995 glxi
i Had my servo bypassed, however, the after effect was black soot staining my stainless tail pipe. and I had overfed spark plug/ rich mixture resulting to a carbonized (black dry soot) on my spark plugs....did you guys encountered this? if yes, how did you resolve this? need advice? ASAP
  #22
Old 10-01-2017, 09:06 AM
albabz1902's Avatar
Default Hello sir. I know this thread is too old. But i am experiencing this problem now.
Originally Posted by chis51hd
Hello everyone. I own a 1994 Lancer GLi (4G15 engine) with 87,000km. on it. After purchasing the car I noticed that the engine wouldn't idle up when the airconditioning was turned on. I took it to my usual mechanic, but they couldn't find the problem. So we went to another mechanic who specializes in fuel injected/electronically controlled engines. He immediately found that the idle control servo was defective. He also said that he already encountered others with the similar problem (apparently this is inherent in older Lancer models), and upon replacement of the servo, the problem usually comes back. So we came up with a "solution". We just left the servo as is, and replaced it with a mechanical system. First they installed an actuator--pretty common device, and attached the terminals to the aircon compressor, so it would activate when the aircon is turned on. Then tapped an air hose (not sure which one) to supply airflow to the actuator. Then attached a sort of vacuum hook to the throttle body. When the actuator is activated by the aircon, it also activates the vacuum hook and pulls the idle "thingy" (the one where the accelerator cable is attached to), and brings the rpm up to 1,000. Problem solved.
I just would like to know if anyone else has tried this, and if there would be any ill-effects to this procedure? The car runs fine, and engine idle is sufficient when the airconditioning is turned on. I can see that it's a pretty simple fix, and I only spent about $20 (parts and labor).
Hope to hear your opinions on this. Pictures below:
[img]local://upfiles/12443/7165C31FBF7B4034A955686741082842.jpg[/img]
[img]local://upfiles/12443/B679E51BC8224963B2A9317A7DD22528.jpg[/img]
I hope you could also help me with my problem
  #23
Old 04-01-2018, 10:07 PM
zico's Avatar
Mga idols,
Patulong naman sa 96 Lancer GLi ko na biglang nag high idling pag start.
Nung una pag apak ng gas bumababa, pero yesterday nag maintain ng 2k rpm pag nakatigil and minsan kahit tumatakbo.
Pag dating ko sa bahay at saka lang bumaba ng around 500 rpm.
Paki advice naman kung ano dapat kong gawin.
Thanks in advance.
  #24
Old 11-12-2018, 07:32 AM
Eric A. Custodio's Avatar
Default Replace
Originally Posted by zico
Mga idols,
Thanks in advance.
replace servo or IAC that's it.
Randys
08-12-2013 06:07 AM
kojy2k
07-26-2009 04:25 AM
emills61074
06-26-2006 05:20 PM
jrk247
04-02-2005 02:48 PM
1398spdr
03-16-2005 07:29 AM
Quick Reply: Defective idle control servo... Improvise!
