Headlight problem
I have an 09 Lancer GT. Recently one of my headlights went out. When I tried replacing it I realized that it's not the bulb (as I tried two other bulbs and still nothing).
I checked fuses and all is well. Any ideas before I have to waste my time going to dealership? |
I don't understand the question?
Why would the right headlight not work. I have tried two other bulbs and nothing.
Headlight problem
I wonder if anyone has had a similar problem. When I push down the headlight switch from the sidelight position, the sidelights, taillights and daash lights all go out. So I have nothing when its in headlight position, if I pull main beam it works.I have checked the fuses, they are all ok.
Headlight problem
So my passenger side headlight is not working correctly. The low beam does not work, but the high beam works. I am assuming this is not an issue with the bulb since the high beam works. I checked the fuses and they all looked good. Anyone have any ideas as to what is wrong? Could this be a bulb problem??
Originally Posted by Angetty09
(Post 254184)
