laurenvegan87 |
04-09-2012 06:37 PM |
Intermittent Stalling on 2005 Lancer ES - any suggestions?
So my 2005 Lancer ES with 112k miles that I've had for about 5 years has some kind of issue. About a month ago, shortly after I got an oil change and replaced the air filter it started stalling out intermittently while idling in traffic. It doesn't throw any codes, so I had the spark plugs, plug wires, and fuel filter changed (I also put a tank of 93 octane in, in case it was a bad gas issue). Unfortunately, it's still doing its stalling thing. The problem is most pronounced after a highway stint with a steep off ramp - then, even with decent forward momentum but little or no gas pressure it will stutter and want to stall (but generally keeps running). The car is not throwing any codes (mechanic checked it, and then my buddy used his code reader too) and the check enginge light doesn't come on - but the check engine light isn't broken, because it does light up when all the lights up if the car is on but the engine isn't. I got some fuel additive in case it is, in fact, a fuel issue - but I've gone through several tanks of gas in the last month. Going to put it in once the tank is mostly empty. Any suggestions would be greatly appreciated, I'm running out of ideas and patience!
