MZ360272EX Remote engine start problem
Hello,
I have 2009 Lancer 1.8 CVT. I bought remote engine start from E-bay. I put it to my car correctly I am sure abut it. I’m trying to program the remote and everything works as it should but at the end of the key programing the doors are supposed to lock and unlock twice and then the programing is complete. This part is not happening any guidance on what to do would be greatly appreciated ? |
Have you contacted the make of the remote starter Co....
Installation complated correctly i am sure
After installation 1-Close all doors and remove ignition cnob cap. my car has f.a.s.t. key 2-insert the emergency key into the ignition knob. Turn the knob from LOCK (OFF) to ACC to LOCK repeat this 5 times within 10 seconds, and ecu beeps one time 3- within 10 seconds after the sound of the buzzer, push three buttons and remote light flashing 4 -while the light flashing on remote controller. Insert emergency key into the ignition knob and turn the knob from LOCK (OFF) to ACC to LOCK and than buzzer beep once. Remove key 5- perform the engine stop operation by the remote controller and buzzer beep twice Everything ok on this point but I can not perform last 6. Step 6- within 10 seconds after the beep, using press the door unlock button three times successively than nothing. it could be doors locks should automatically lock and unlock twice than registration will be complete but my car nothing |
Let us know how you make out on the forum bud.
I think, my car remote system works 415mhz and remote engine start 315mhz. I have to change frequency.
i finally did. i change my immo antenna and keys for 315mhz and now remote engine start work perfectly
