Replacing Rockford Amp '09
I have a Lancer ES 09 w/ Sun & Sport. It has a salvage title because it had water damage. Luckily all that got damaged was the amplifier since its on the floor. It has a permanent short in it now that slowly pulls from the battery so if you don't drive it for 2 days it will die and require a jump. This can be avoided by disconnecting the radio fuses but that kind of sucks.
I don't really care about the amp's quality at this point, I just want my car to start up. I'm looking for the part number of that amp or something that will substitute for it. I'm not looking for anything fancy ... this is my wife's daily driver. Thanks for any help you can offer. |
moving over to tech help..
amp
if youve a mmcs headunit theres a way of running sound directly from unit by rerouting audio back but its tricky , easier to replace with a used amp same or strip casing on unit and clean with electronics cleaner and a soft brush to get furring of electronics and leave in a warm place to dry for 24 hours , might fix it
I want to replace it outright but don't know the part number to use.
... still desperately looking for a part number if anyone can help out.
