signal lights not works
Please anyone, my signal lights and the hazard flasher do not work:(:(
I check fuses, everything look ok. i think that problem could be a relay, but I donīt know where is it. :(:(:(:(:( please helpme, where is it or if the hazard flasher button also include a relay. thkz |
so what are you asking ????
You can check a relay by passing a small amount of current through it.
If you don't have any electrical diagnostic experience, then you should take it to a shop. We can't help you from over here. |
ok, my signal lights donīt work, I check fuses, he only I caīt check is the relay because i donīt know where it is.
my cuestion is, where is that relay, the signal lights relay. |
It is located behind the plastic kick panel below the steering wheel, above the pedals.
ok. let me try one by one of those relay to get the broken one...
tkz |
