Squealing noise
When I started my car today there was a really loud squeaking noise coming fromt he engine that I never heard before. It was wet out, and I probaly just figured that there was moisture on the power steering belt, but I'm not too sure. Do you guys think it's just the power steering or something else?
RE: Squealing noise
By the way its a 02 lancer OZ...if that makes any difference
RE: Squealing noise
Alternator andpower steering belt, Bearing from the Alternator.
One of them should be the problem. need replacement or just need to be tighten |
RE: Squealing noise
Check the belts for any cracks and glazing.
RE: Squealing noise
Ya I checked the belts...seemed to be no problem. I didn't have any problems before with it, and I haven't had any since. I just thought it was really random that it just made that noise like that.
RE: Squealing noise
Well if they look ok check the belt tension, they just probably need to be tighened a little bit like what beat said.
RE: Squealing noise
Alright thanks!
RE: Squealing noise
It just starting to break if you just started tohere the noise
Put onyour heater or ac while driving. You will hear a squealing sound once in a while especially when its wet. if so check bearing for the alternator it should be in front of the engine near the radiotor left side. facing the car. But if you want change theSerpentine beltmake sure Your mechanic will NOTFORCE THE BELTONTHE PULLEY OR ELSE HE/SHE WILL break the Oil Seal orCrank Sealor other parts holding the Pulleys. That will be another huge oil leak and big problem. |
| All times are GMT -5. The time now is 07:12 AM. |
