01 de swap
i have a 2001 mirage de coupe. I do not want to put forth the time to modify the 1.5 L engine enough to become what i want it to be. Wat are possible engines that i could put in it. Would a FWD 4g63t engine fit. And if so how much would it approximately cost to modify the engine bay to fit.
I think we need to make a sticky on this, cuz it's been covered about a zillion times. Unless you've got money comming out your ears and can fab your own engine mounts, and can afford to have your car down for about 3 months, you're pretty much SOL. 4g63T WILL NOT bolt into a 5th generation Mirge. That is unless you pull one out of an Evo VIII, but then you've still got to worry about motor mounts, transmission & differentials, drive shafts, converting to a 5 bolt pattern if you're wanting to keep the AWD, and a general slew of other problems. It can be done quite easily in a 4th gen car, but anybody 1997 and up has a very limited number of options when it comes to swaps. All this, and considering the fact that to correctly do a 4g63t swap into a 5g rage would cost your somewhere in the neighborhood of $10-12k. I don't know about you, but if I had 12 g's, I'd be using them as a downpayment on a real Evo.
By the way, just an afterthought, importing an Evo V motor & tranny will do you no good either, since they though they look similar, the Evo IV, V & VI use a different frame than what a USDM 5th generation Mirage does.
Welcome to the forum by the way, lol
So what !
I also have a 5G mirage and would like experts comments, not like morons like you.
For sure if I'd opened a new thread, there would be another moron telling me to look in the forum and post in already opened threads regarding this matter.
Any expert person who can tell me if at least engine to tranny are the same?
Would be nice to swap an engine like this 4G15 MIVEC in a 5G mirage. For sure Iknow that the ECU is a musT. Still don't know how to deal with the " drive by wire issue" in case that this swap was possible.
