1995 Mirage 1.5L Auto - Cold start sputter
I've got a 1995 Mitsubishi Mirage with a 1.5L motor and auto 3 speed tranny that i use for my DD which has a couple issues i'm trying to figure out. First issue, when i start the car when cold, it will sometimes take a quick blip of the throttle to "catch" and stay running otherwise it'll die once and will start right up on the second attempt. Second issue is that after its started cold, it'll idle fine in P or N, but if i go into D or R it'll really sputter for a few minutes at low rpm until the engine warms up. Once its warm (after about 5 min of driving) it is completely fine, will idle with no issue, start up with no issue, and is smooth.
This car was just purchased about a month and a half ago so i'll go into what i've replaced myself as well as what the P/O had in the sale ad. Recent parts I've persronally replaced or cleaned: Coolant Temp Sensor replaced All 4 spark plugs replaced All 4 plug wires replaced New oil change with oil filter Restore oil additive with oil change Cleaned IAT sensor Cleaned EGR and intake opening All 4 fuel injectors replaced P/O claimed replacements: Catalytic converter about 4 years ago New battery (verified) New timing belt (verified) New accessory belt (verified) New starter New distributor I'm pretty much out of ideas...the CEL is on but the obd1 readers i've tried will not read the code. They'll power up when connected but wont read. The P/O had an intake they had made for this car on it when i bought it...it was made from steel exhaust pipe and the vacuum line was just hanging free. I ended up taking the pipe off, remade an intake pipe from PVC, and tapped a vacuum hose connection back to the motor and finished it off with a KN filter. Thats pretty much all i know on the vehicle. My ideas are as follows but am hoping to get some better insight or ideas: Vacuum line leak somewhere Possible fuel pump going bad Possible problems from the intake (just not sure what from) Thank you for any and all help in advance!! |
i need to start a parts business!!
Start it with quarter throttle. Put in N. Hold rpm at 1500, it should stay quite easily, <1min the engine will pick up speed without you giving it more foot. Stil drive smooth/gentle for a while, but should halp. Small, Old engine, possibly reed valve that controls warm air intake. |
