1995 mirage compression test help needed
I have a 1995 mirage 1.5 and i am doing a compression test on it, the cylinder pressures i am reading are 1-4 = 110,0,45,0. I need to know what the proper cylinder operating pressure would be.can anyone find this info in the manual.
Woa....well i can tell you without a doubt that yours are not good even without knowing the correct compression with that engine. Even the 110 seems alittle low (but again i dont know what your engine is supposed to be) but guarenteed that the others are all very bad. Did you break a timing belt or something?
