95 mirage timing 1.5l
Im working on my friends 95 mirage 1.5l. it bent a rod and destroyed a piston when he was trying to use the car as a jet ski. well i have some doubts on how to set the timing right. since the motor was stuck i couldnt move the timing mark into place and i had to tear it apart as it was.
i have a manual i downloaded online, what i need to know is: whats the piston diagram? which one is #1 and the others? the crankshaft gear is the smaller and this motor moves two pistons up and two down simultaneously. can i align the crank timing gear in the mark and thats it? if the ratio is 2:1 should i worry about getting the right turn or setting either of the turns is the same thing?? as long as i set the head right?? thanks for the info!!! |
RE: 95 mirage timing 1.5l
We cant help you sorry you broke the piston and rod.
Engine rebuilt is the best way. |
Here you go http://www.gen-parts.com/pdf2/0C1947.pdf
