'99 1.5 APP switch circuit
I had my check engine light come on, so I went to AutoZone to have my codes run. I got 2 code: P0510 (Accelerator Pedal Position switch circuit) and P0302 (Cylinder 2 Misfire)
I was looking at my accelerator pedal, and there is no electornics on it at all, it is linked directly by cable to the throttle body. Could this instead be a Throttle Position Sensor error? Also, does anyone know the cylinder numbers? I don't have the owner's manual, and can't seem to be able to find a repair manual for it. Thanks. |
cyls numbered 1-2-3-4.
I would hazard a guess that if it was tps, it would throw a tps code. |
I got the codes ran again, this time the guy said it was an APP/TPS error, so I switched it out and got the codes reset. I think the mis-fire error was probably from an exhaust leak that I had fixed a couple days ago. We'll see if they pop up again.
