aftermarket tachometer wiring
Hello all,
My son owns a 1995 Mitsubishi Mirage 1.5 engine with a manual transmission. He purchased a aftermarket tachomater andI am not sure how to connect the green distributor / coil wire. I dont know much about this car but I dont see a coil and there is no center wire from the distributor cap. Anyone with any experience on where this wire connects too? Thanks for any help. Kevin |
RE: aftermarket tachometer wiring
You can get tach at any injector. Get a digital multimeter with a good set of test leads, set it to AC and connect to the uncommon wire at the fuel injector (there are 4, so just pick one). You should see roughly 1 volt AC (could be as low as .6), and it will rise and fall with the motor's speed. Strip that wire back, take a pick tool and makea hole in the wire and insert the wire going to the tach into it. Wrap tightly around the injector wire, solder and tape. Add a zip tie for stress relief, and there ya have it, TACH!!!
lol, good luck. |
Sounds easy but it is not.
ORIGINAL: BEAT Sounds easy but it is not. |
will this work on a 02 mirage 1.5l auto?
yes it will
thanks, i just joined here and i can't find anything with the search
i know this is an old thread, but i just purchased a 2003 mitsubishi mirage CE 1.5L manual, it does not have a tachnometer so i purchased an aftermarket tachometer, i connected it up as per instruction on the forum and it does not work, where else can i connect it to?
Tach Signal Found !!
To everyone out there,
i found the tach signal! on the distributor, there will be a plug (7-pin plug) looking at the plug, you have a black wire (1), followed by a white wire (2), there are two white wires, strip back a section of the white wire next to the black wire OR cable splice it using a connector, this will give you a tach reading, goodluck to all |
tach signal
I assume this connector is also on a 1999 Mirage DE Coupe M/T?
